Inventor General
New Member
hansjb
Message 1 of 6 (190 Views)
Unable to create Flat pattern
190 Views, 5 Replies
05-03-2012 05:50 AM
Hello All,
I'm unable to create a flat pattern, Any suggestions would be appreciated.
Thank you,
SlowCad
Message 2 of 6 (186 Views)
Re: Unable to create Flat pattern
05-03-2012 06:12 AM in reply to: hansjb
Put dimensions and constraints in the sketch and use same thickness in the whole sketch.
Also be sure to enter sheet metal rules for the thickness of your sheet.
Good luck
Message 3 of 6 (155 Views)
05-03-2012 10:47 AM in reply to: hansjb
Problem 1
As indicated - Your sketch is not constrained - read this
http://home.pct.edu/~jmather/skillsusa%20university.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 4 of 6 (154 Views)
05-03-2012 10:48 AM in reply to: hansjb
Problem 2
Your part is not uniform thickness, but sheet metal requirement is uniform thickness.
Message 5 of 6 (153 Views)
05-03-2012 10:49 AM in reply to: JDMather
Problem 3 you used Extrude rather than sheet metal tools?
Message 6 of 6 (150 Views)
05-03-2012 10:54 AM in reply to: JDMather
Problem 4 - you are doing too much work, get lazy.
Edit Sketch1 and notice only one side open profile needed.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
