Inventor General
Member
papagoosebob
Message 1 of 7 (488 Views)
Accepted Solution
Unable to Edit an iPart via Spreadsheet
488 Views, 6 Replies
07-19-2012 12:15 PM
I try to edit the table of an iPart via a spreadsheet (EXCEL 2010) and it does not launch EXCEL.  I saw other posts with changing the registery and I am not too confident on what to remove or even how to do it.
I am running Window 7 with Inventor 2012 and Excel 2010.
*Expert Elite*
Cadmanto
Message 2 of 7 (487 Views)
Re: Unable to Edit an iPart via Spreadsheet
07-19-2012 12:30 PM in reply to: papagoosebob
Welcome to the forum.
Does the ipart table eidtor not do what you are trying to do when you select the editor in the browser when you select "table"?
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Member
papagoosebob
Message 3 of 7 (482 Views)
07-19-2012 12:37 PM in reply to: papagoosebob
With Excel you can change the order of the columns.  With Excel you can edit the values much faster than in the table editor. You can also add multiple rows much faster.  It is a feature that is not working on my Windows 7, but works on Windows XP.
*Expert Elite*
Curtis_Waguespack
Message 4 of 7 (481 Views)
07-19-2012 12:38 PM in reply to: papagoosebob
Hi papagoosebob,
I think this link should get you going:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14079866&linkID=9242018
Note: I had to use Internet Explorer to view the video (rather than FireFox)
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Member
papagoosebob
Message 5 of 7 (478 Views)
07-19-2012 12:40 PM in reply to: Curtis_Waguespack
I saw that, the video does not play, and there is no reference on what lines to remove from the Register.  Also the statement "Warning! Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft provides a wealth of critical information that you need to know about the registry in the Microsoft Knowledge Base at http://support.microsoft.com/support." scares me
*Expert Elite*
Curtis_Waguespack
Message 6 of 7 (473 Views)
07-19-2012 12:46 PM in reply to: papagoosebob
Hi papagoosebob,
I had to use Internet Explorer to view the video (rather than FireFox).
If the registry edit spooks you (and kudos to you for being cautious) then you might just tap your friendly IT profesional to do this. But I have a hunch that if you watch video you'll feel okay with it.
Of course it's always a good idea to backup the registry before making changes:
http://windows.microsoft.com/en-us/windows-vista/Back-up-the-registry
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2892585&linkID=9240617
I hope this helps.
Curtis
Member
papagoosebob
Message 7 of 7 (463 Views)
07-19-2012 01:37 PM in reply to: Curtis_Waguespack
Thank you Curtis,
After finally viewing the video on WIindows XP IE (Windows 7 did not work), I was able to edit the register and it works now.
Thanks again,
Bob
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
