Inventor General
Active Contributor
lemaycj
Message 1 of 15 (186 Views)
Accepted Solution
Tutorial Problem
186 Views, 14 Replies
10-19-2011 10:20 AM
I'm still going through the tutorial.  I'm only on Create the part from Scratch.  Obviously I have Options not setup as in the tutorial because simple thing lile the coordinate system indicator was on in Sketch and preventing me from picking the 0,0,0 point.  When I try to add a constraint to my rectangle to center it over 0,0,0 it gives me a message that it would be overconstrained and won't do it.  I can go on and add equations to the general dimension.  But the simple task of constraining isn't working.  I've gone back to the Constraining exercises but it won't work for me here....
What do I have to do to make this centre over the axis??
Distinguished Mentor
john.retzlaff
Message 2 of 15 (173 Views)
Re: Tutorial Problem
10-19-2011 10:42 AM in reply to: lemaycj
Like this.
John Retzlaff
*Expert Elite*
JDMather
Message 3 of 15 (171 Views)
10-19-2011 10:43 AM in reply to: lemaycj
Following the steps in the Tutorial -
On the Constraints tab click Horizontal
then click point 1 (the green projected origin) and point 2 then midpoint of the left vertical line.
What happens?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Contributor
lemaycj
Message 4 of 15 (162 Views)
10-19-2011 11:03 AM in reply to: JDMather
I followed the video pausing at every step to check the messages against what I get.  As soon as I pick a line on the rectangle, right away a message of overconstraining comes up.  I started over 4 times with the same results every time.
It must be something in the setup of Inventor or Inventor Options that is doing this.
It's a really simple task and it's really bothering me that I can't do it.
john.retzlaff
Message 5 of 15 (160 Views)
10-19-2011 11:05 AM in reply to: lemaycj
Have you closed Inventor and restarted?
John Retzlaff
Active Contributor
lemaycj
Message 6 of 15 (159 Views)
10-19-2011 11:10 AM in reply to: lemaycj
I changed a setting in Inventor/Options/Sketch: Overconstrained dimensions to Apply driven dimension.  Re-started Inventor, new part created with the same template.  As soon as I click on the line on the rectangle the message window appears: "Autodesk Inventor- Create Constraint: Cannot constrain or dimension reference or fixed geometry".
john.retzlaff
Message 7 of 15 (145 Views)
10-19-2011 11:41 AM in reply to: lemaycj
I edited the sketch on the part you posted with no problems.
Not sure why you are having this problem.
John Retzlaff
*Expert Elite*
JDMather
Message 8 of 15 (143 Views)
10-19-2011 11:45 AM in reply to: lemaycj
It sounds like you are clicking twice on projected geometry.
Active Contributor
lemaycj
Message 9 of 15 (138 Views)
10-19-2011 11:56 AM in reply to: lemaycj
This is what I have been doing, over and over:
I start a new part, it opens up in sketch mode already and I click on rectangle, pick two points  across for the latter, hit ESC, then horizontal constraint, I then pick the 0,0,0 location, then a vertical line on the rectangle and bang the message window appears.  I just don’t know what it coud be…
Distinguished Contributor
kstate92
Message 10 of 15 (129 Views)
10-19-2011 12:16 PM in reply to: lemaycj
When creating the rectangle, do any constraint glyphs (horizontal, vertical) appear?  After placing a rectangle, what results when selecting autoconstraints?
KState92
Inventor Professional 2014 64 SP2
Windows 7 Pro 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
