Inventor General
Valued Contributor
Message 1 of 6 (480 Views)
Accepted Solution
Turning lots of features on and off in ilogic
480 Views, 5 Replies
10-06-2010 08:39 AM
Is there a better way to turn alot of features on and off than haveing it turn them on and off for each case?  I have put the code but this takes a while to process and I was wondering if there was a faster way to make this happen than markign each one for being turned on or turned off.  I am using 2011 and this is ilogic for a multi body solid that will be made into an assembly later.
'EFFLUENT RULES FOR TURNING FEATURES ON AND OFF
If EffluentType="Drop Pipe" Then
    Feature.IsActive("DropPipeFlange")=True
    Feature.IsActive("DropPipeEndRim")=True
    Feature.IsActive("DropPipeExtrusion")=True
    Feature.IsActive("DropPipeCut")=True
    Feature.IsActive("DropPipeChannelEnd")=True
    Feature.IsActive("EffluentChannelRim")=False
    Feature.IsActive("PipedEffluentTrim")=False
    Feature.IsActive("PipedEffluentFill")=False
    Feature.IsActive("PipedEffluentPipe")=False
    Feature.IsActive("PipedEffluentFlange")=False
    Feature.IsActive("PipedEffluentCut")=False
    Drop = iFeature.FindRow("DropPipeFlange", "PipeDiameter", "=", EffluentPipeDiameter)'Change iFeature Flange size
    iFeature.ChangeRow("DropPipeFlange", Drop)
ElseIf EffluentType="Channel" Then
    Feature.IsActive("DropPipeFlange")=False
    Feature.IsActive("DropPipeExtrusion")=False
    Feature.IsActive("DropPipeCut")=False
    Feature.IsActive("DropPipeChannelEnd")=False
    Feature.IsActive("EffluentChannelRim")=True
    Feature.IsActive("DropPipeEndRim")=False
ElseIf EffluentType="Pipe" Then
    Feature.IsActive("PipedEffluentTrim")=True
    Feature.IsActive("PipedEffluentFill")=True
    Feature.IsActive("PipedEffluentPipe")=True
    Feature.IsActive("PipedEffluentFlange")=True
    Feature.IsActive("PipedEffluentCut")=True
    Piped = iFeature.FindRow("PipedEffluentFlange", "PipeDiameter", "=", EffluentPipeDiameter)'Change iFeature Flange size
    iFeature.ChangeRow("PipedEffluentFlange", Piped)
End If
Employee
Message 2 of 6 (475 Views)
Re: Turning lots of features on and off in ilogic
10-06-2010 09:09 AM in reply to: josephcooley
Every call to Feature.IsActive will do an Update, so it can be slow.  As a workaround, you can have the rule set the end-of-part marker to the top of the model tree.  The part will be temporarily empty, and updates will be fast.  Add this to the top of your rule:
DipartDoc as PartDocument = ThisDoc.Document
partDoc.ComponentDefinition.SetEndOfPartToTopOrBottom(True)' Set to top
Dim partDoc as PartDocument = ThisDoc.Document
And add this at the bottom:
partDoc.ComponentDefinition.SetEndOfPartToTopOrBottom(False) ' Set to bottom
If you need more control over the end-of-part, there is a way to move it before or after a particular feature.
Mike Deck
Software Developer
DLS - Mechanical Design
Autodesk, Inc.
Valued Contributor
Message 3 of 6 (472 Views)
10-06-2010 09:29 AM in reply to: MjDeck
the colors of all that text is brown (like its incorrect maybe)  Should it be purple like the rest of the commands?
ThisDoc.Document is purple and Dim is red  I just wanted to make sure this is correct the rule closes and like there is no syntax error but I wanted to make sure there was no error.
Employee
Message 4 of 6 (468 Views)
10-06-2010 09:37 AM in reply to: josephcooley
Those colors sound OK.  Most of that code is Inventor API code (not iLogic functions), so iLogic doesn't show it in purple.  Dim shows up in red because it is a Visual Basic keyword.
Mike Deck
Software Developer
Autodesk, Inc.
Valued Contributor
Message 5 of 6 (462 Views)
10-06-2010 09:40 AM in reply to: josephcooley
Thanks that worked I think.
Active Contributor
Message 6 of 6 (172 Views)
11-15-2012 06:20 AM in reply to: MjDeck
I think moving the End Of Part could be useful for a rule I am setting up. How do you go about writing a command to specify where to move the EOP to?
Sorry for jumping into an old thread.
Ian Farmery
Inventor 2010 Pro SP4, Vault Collaboration 2010
HP Z820 Xeon E5-2643 0 @ 3.3Ghz 16.0GB RAM
Nvidia Quadro 5000
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
