Inventor Forum
Turn Off Visibility of Diameter Dimension Extension Line
13 REPLIES 13
Message 1 of 14
beau-tech
1939 Views, 13 Replies
I searched the forum and found a couple of discussions regarding the subject in 2009. It's 2012 and I have the same request (see attached). I haven't found a setting in the dim style or the RMB options to turn off the extension line. I saw the posts showing drawing a sketch in the view but come on, all that to just turn off the line?
Thanks.
Pete
IV 2012 all sp & fixes
13 REPLIES 13
Message 2 of 14
SBix26
in reply to: beau-tech
I agree!  This is a significant shortcoming in the drawing manger.  Your illustration shows it very well.
Message 3 of 14
Cadmanto
Pete,
What happens if you rotate the diameter dimensin around.  Does the extention shorten and almost disapear?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 14
dan_inv09
in reply to: Cadmanto
It's just going to go the other way.
Message 5 of 14
SBix26
in reply to: dan_inv09
I just submitted this to the Autodesk product comment site (otherwise known as the wishlist).  I'd encourage others to do the same.  I asked for the ability to control visibility and attachment point of diameter dimension extension arcs.
Message 6 of 14
beau-tech
in reply to: SBix26
Ok, thanks. I'll go there and submit the request.
Message 7 of 14
bobvdd
This has been logged in our wishlist database with number
1336903 Unwanted extension line of diameter dimension
Bob
Bob Van der Donck
Principal UX designer DMG group
Message 8 of 14
TedescoATC
in reply to: bobvdd
Has a resolution been found for this?  I couldn't find anything in the service pack or hotfix readme's.
Message 9 of 14
LSKELLY
in reply to: TedescoATC
A good workaround is to
1) Sketch a circle on the view and constrain it.
2) Close the sketch
3) Dimension the circle.
4) Open the sketch
5) Select the circle and set as "sketch only"
But a programmed solution would definitely be better.
Message 10 of 14
llorden4
in reply to: bobvdd
Bob
2018 and STILL on my wish need list!
Autodesk Inventor Certified Professional
Message 11 of 14
bobvdd
in reply to: llorden4
No comment other than to keep voting for it on the Ideastation at
Hide extension for diameter dimension in drawings
Thanks for your patience.
Bob
Bob Van der Donck
Message 12 of 14
dfilbrun9L4GF
This is what works for me:
Make a new dimension style for that dimension, and under the Display tab, increase the value for B (Origin Offset). Different diameters will require different values for B, and you have to keep adjusting until you find the right value. The larger the diameter, the greater the B value needs to be.
This works, but is NOT the ideal way for doing it. Hoping that Autodesk will still incorporate this option in the settings.
Message 13 of 14
Making the B value to be 2/3 of the diameter seems to work well.
Message 14 of 14
Ignore my last post. 2/3 of the diameter only works for around 20" diameter. For approx. 2" diameter, I had to use 4 times the diameter.
