1) Create an iPart for the standard.
2) Click on the Create Fitting icon on the part modeling panel bar.
3) Enter all of the information and publish it to the library.
Once the standard is published to the library, you can select it from the
Style dialog.
Quite a bit of information is captured when you publish a pipe or fitting.
You should probably review the help topics before you go through the
process.
Loren Jahraus
Autodesk Inventor Workflow Team
"BZirkle" wrote in message
news:f17cd9e.-1@WebX.maYIadrTaRb...
> I realize that having upgraded to AIP and posting this question is likely
to make me a very unpopular person on this NG, but here goes...
> When AIP was demo'd to me early last week, I was shown how the tubing
router works and led to believe that I could create my own styles of tubing.
I work primarily with DIN 1630 and DIN 2391 steel seamless small diameter
metric tubing. So far, after installing AIP, I have found no way to create
my own tubing styles, only to modify or copy and then modify existing
styles. Unfortunately, this isn't helping me because I can't change tubing
OD's and Id's from the standards which are already established. Has anyone
with AIP gotten this to work? and could you clue me in on how, 'cause I'm
just not finding it. Thanks.
> Brian Zirkle
> Manufacturing Design Engineer
> Vogel Lubrication, Inc.
