I have problem with tutorila Tube and Pipe Tutorials , Self-draining Lines ,Create the Self-draining (6)
When i finish step 15 (click Save) and want to close i see problem- Save Edits?
windows 8.1 Inventor 2015
This doesn't look like a problem, it's just asking you if you want to save the new Tube & Pipe style you've created. Click yes. If it doesn;t let you save,.... now you have a problem.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I have this problem with Inventor 2015 windows 8.1 and windows 8.
I try this problem missing with inventor 2014 windows 8
This is a real problem.
As cbenner said, it doesn't let you save.
Normally the save button would became disabled if the style is successfully saved, but for this tutorial, it's not. Then if you close the dialog, it would ask if you want to save the style, and you click yes, then it go back again! See the attached video.
Don't know why. If I select another 88° elbow in CC, it will save with no problem. Maybe the custom elbow part provided by the tutorial is broken somewhere.
Inventor 2015 SP1 Update 1, Windows 7 Sp1 x64.
