Inventor Forum
Tube & pipe not starting
3 REPLIES 3
vmcarbonneau
340 Views, 3 Replies
Here is my problem
When I start Tube and pipe environment, Inventor stops responding and I have to end the process manually.
If I start Tube and pipe environment in a new assembly, it's working. After I successfully create a Tube and pipe assembly in a new assembly, I have no more problems starting Tube and pipe environment in other assemblies. Each time I want to use Tube and pipe, I have to create one in a new assembly.
Inventor insallation is fresh with SP1
What is wrong ?
3 REPLIES 3
cbenner
in reply to: vmcarbonneau
SP1 for which version of Inventor?
Can you describe your exact workflow?  You have an assembly, in which you have already used Tube & pipe, and created a pipe run.  What do you do next?
vmcarbonneau
in reply to: cbenner
Inventor 2014
to make it works:
step 1
- create a new assembly
- save this assembly
- create a tube & pipe run
step 2
- open the assembly where I want to use tube & pipe
If I don't do the step 1, it's not working
cbenner
Well, that does not seem right.
I know I've seen posts before about t&p and 2014... but a quick search revealed no solutions.  I don't have 2014 to check this out on... but I suspect it may be an issue with this release.  I would urge you to log a tech support case with this one.
One person said they changed somehting in the registry to fix their problem,.... I don't advocate that.
