Hi There,
I'm new here so please be gentle with me.
I'm up to putting in some hydraulic lines from a pump to some hydraulic rams and am looking for some really good , basic, easily to understand tutorials,or failing that, some solid help and advice. I've looked through Youtube and there's not much there that i could see.
My line comes through a bulkhead and I want my hydraulic pipe to go straight for about 100mm, bend down then go straight up to connect with a 90°bend coming out of the ram. I've tried to add various points when creating the route but it all seems to get tangle up in the rest of my work, and I cannot seem to put points on the line like a spline and move them. See attached pic
Best Rgds,
Dave R
Dave,
You know what? It is not about whether your method follows protocal, it is what works for you!!!!
Congrats on finding something that does.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
