Inventor Forum
Trying to place cross dowels into multipule holes easly
2 REPLIES 2
Rherman
392 Views, 2 Replies
I am trying to place a cross dowel into multiple holes. Is there an easy way to automate this? Currently I am placing a cross dowel component and then constraining it to the hole one at a time. Quite a long process to place hundreds of them.
Thanks for the help!
2 REPLIES 2
japike
in reply to: Rherman
Check out imates or Pattern Component using Feature Pattern Select.
Peace,
Jeff
Inventor 2022
mcgyvr
in reply to: japike
Or kwiksert (great addin) Not free but easily worth every penny if you do this quite often.
You could also try the "assemble" workflow/dialog instead of the regular constraint dialog.
