Inventor Forum
Troubles with splines
7 REPLIES 7
Message 1 of 8
GavinReynolds2021
1932 Views, 7 Replies
I have run into something new that has caused me to loose what little hair I have left. I am drawing what essentially looks like a wing rib and after getting the basic shape I found out that I am unable to fillet a spline to a simple line...which is annoying. I then drew the voids inside the shape which were annoying because i couldnt fillet to the offset spline. At some point in this process I had a closed loop which would extrude but in messing around trying to fillet the small end of it I lost something either in constraints or loop closure. I now cannot select the body of the part for extrusion. I have used the loop doctor which identifies several problems I have attempted to fix but when I ask it to close the loop I get an error saying it failed to create the incident constraint and that some points lie of the same curve. I am stuck. Any help would be appreciated. This is the first time I have has to use more than a simple spline and I am not sure what I have fouled up.
Thanks for any advice
7 REPLIES 7
Message 2 of 8
First thing I notice is that you are missing a lot of dimensions and your sketch is not constrained to the origin (floating in space) which makes it difficult to determine your design intent.
Then I noticed that in some locations you used Splines where it would seem to make more sense to use Arcs.
And then I saw overlapping constrained endpoint splines with a tiny line?
I also saw lines that appeared to be vertical but upon dimensioning - showed slight angles.
Inventor should automatically be applying Vertical Constraints (and others) while you are sketching.
I recommend that you put this project aside for a couple of hours and go through these.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
Message 3 of 8
As Jeffrey mentioned, there's lots of unnecessary geometry.
I've cleaned it up a bit.
Walter
Walter Holzwarth
Message 4 of 8
Hi! There is indeed something not right here. There are gaps between the upper spline and the vertical lines. It seems like the fit points are detached from the spline, which does not make sense to me. I delete the constraints and add the coincident constraints back. Then run it through Sketch Doctor when editing the sketch. After that, the profile becomes healthy again. Do you know how to reproduce the detached fit points?
Many thanks!
Software Test Engineer
Message 5 of 8
Thanks for the useful links They helped a lot with understanding the problem
Message 6 of 8
Thanks for that, your approach with the fillets makes a pile of sense now that I have seen it. I am really looking forward to getting some training in the next few weeks. Its tough going when I have no one else here to collaborate with. I really appreciate you taking the time to clean it up
Message 7 of 8
Thanks to you all for taking the time to look at this problem. As always I have learned more than I bargained for but I appreciate the input and different approaches.
Message 8 of 8
You will get more out of the training if you go through the tutorials first.
You might even pick up some tips and tricks that the trainer doesn't know.
