I'm trying to make a single iFeature that includes 3 model-browser features (a cut, a flange, and a face)
The cut is a simple rectangle (it includes a point in the center for placement later).
Then there are four 1" flanges facing the same direction on the four edges created by the cut.
Then there are four faces to fill-in the relief area created by the flanges.
When I select all three and click "Extract iFeature", only the cut appears in the subsequent window (and .ide file from it).
If I select either the flanges or the fill-ins, nothing appears in the iFeature creator window.
I've attached the IPT file.
Hi Claudio,
not all features, specially in the sheet metal part, can be included in an iFeature.
I hope that it can helps you
Admaiora
