Inventor General
Orbitron
Message 1 of 5 (863 Views)
Trouble with Adaptive Part
863 Views, 4 Replies
12-17-2012 08:18 AM
Did a quick search, but did not find anything particularly useful.  Using Inventor 2013.
I wanted to make an adaptive representation of an extension spring.  I made the "coil" of the spring using a symmetrical extrusion.  I made the extrusion "adaptive" thinking the extrusion length would then adapt as required.  I created the "loops" using sweeps attached to the ends of the extrusions.  I made no longitudinal constraints/dimensions to the origin, although I do have one radial dimension to the origin.  Otherwise, both loops are constrained/dimensioned to the ends of the extrusion.
I inserted the part into my assembly and set it as "adaptive".  I contrained one end.  I tried to constrain the other end, but the part would not adapt, so it pulled my assembly out of alignment and caused a conflict with another constraint.
What have I done wrong, or is this not possible?  Thanks
Message 2 of 5 (853 Views)
Re: Trouble with Adaptive Part
12-17-2012 09:20 AM in reply to: Orbitron
Orbitron wrote:
1. ....I made the extrusion "adaptive"
2.  ....I inserted the part into my assembly and set it as "adaptive".
Of course it is possible, but must be done correctly.
1. this doesn't make sense - adaptivity is a result of creating within assembly from projected references.
2. see #1
I prefer to Animate a Parameter in Inventor Studio rather than use Adaptivity.
This topic has been covered here many many times in the past.
Attach simple assembly and someone will show you both techniques (adaptive and driven parameter) for a spring.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Orbitron
Message 3 of 5 (810 Views)
12-19-2012 12:44 PM in reply to: JDMather
Thank you, but that is not what the HELP text and videos suggest, which is what I was trying to follow.
Is it possible for you to provide a link to one of the more useful examples of previous discussions?  I simply do not have the luxury of spending time reading through hundreds of not-so-useful postings.  Thanks.
blair
Message 4 of 5 (805 Views)
12-19-2012 12:57 PM in reply to: Orbitron
Try here, it only takes about 30 seconds to do the seach on YouTube: for the text string: autodesk inventor adaptive
http://www.youtube.com/watch?v=TaKX68LjhUo
Do you realize, the majority of the people that are answering the questions to posts such as this are doing it on a volunteer basis out of the kindness of their hart.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Message 5 of 5 (794 Views)
12-19-2012 02:32 PM in reply to: Orbitron
Attach your assembly here.
When referencing Help information or other sources of information be sure to provide the direct url.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
