My company just started using inventor and we currently are saving our drawings as dwg and saving down to previous versions so that other drafters can still use the older version of AutoCAD to open the DWG files. However yesterday we had a storm that knocked out the power to the office, when the power was restored and we continued our work the files that we create now cannot be opened by AutoCAD or any other software that we use. We keep getting error message that file was created using incompatible version. I checked to ensure that the settings in inventor was still set to save as dwg by default as well save down to 2010. After several hours of searching for a solution I am still baffled at what happen and how to fix it. Has any one experienced this or know how to solve this problem?
Solved by JDMather. Go to Solution.
Have you tried a Repair Install?
I don't want to export the dwg. I want to have just one file that everyone can use. One problem is that we have some CAM machines such as laser cutters and plasma cutters that need to import the dwg files. Up till the power failure at our office every ting worked fine, and now any thing that we draw in inventor and try to use or open we get error created in compatible version. This same message even occurs if we try to open the dwg in AutoCad.
1. My company just started using inventor and we currently are saving our drawings as dwg and saving down to previous versions
2. I don't want to export the dwg.
Your message description leaves a bit to be desired as the above are completely contradictory. But, maybe this is what you're looking for.
Yes the screen shot that is posted is what I am trying to do. What I am saying is that before the power failure at my office the setting that you show is how we were saving our drawings, and everything was working all program that we use could open the files no problem. Now after the power failure even with those same settings any drawings that we create with inventor and try to open with AutoCAD an error message appears that states the file can not be open because it was created with an incompatible version.
Like JD mentioned.....Repair Install. Close Inventor first.
WIndows Start > Programs and Features. Find Inventor in the list, right click and choose Uninstall/Change. Now select the Repair or Reinstall in the center bottom, then Repair radio button.
...turn anti-virus and UAC off during the Repair Install.
If that doesn't work - post back information on Autodesk Clean Uninstall Instructions before attempting a complete uninstall/reinstall.
I have not done a repair install but if I take an IDW and save it as a DWG the files open just fine with the other versions of CAD and software we use; However I am still baffled by the fact that If I use the DWG template and save as a DWG that the files do not open with the other versions of CAD.
twinz3950
Is this localized to one user, computer or project?
It sounds like part of you environment has been corrupted by the power outage.
We are all just trying to assist in figuring out what needs to be repaired with the least amount of impact for you.
How did the repair/reinstall go?
Thank you.
Bob Holland
Autodesk Product Support
You are using the following within Inventor:
I>Export>Export to DWG then select the version from the drop-down dialogue.
