I have a Makerbot Replicator 3d printer for my class. I am having issues when I save my drawing as an stl file bring it up in the Makerware software it decreases the size and I can't get things to scale. I have been in contact with Makerbot for several months and their response is now: "We actually may have had a bit of a breakthrough! Apparently there's something off about the way that Inventor exports files to .stl, and there may be a bug in our software when scaling. Whenever exporting to .stl, especially in metric apparently, Inventor makes the object 10% of the size. To correct for this, can you try scaling your model by 1000%, then exporting to .stl and bringing it into MakerWare? Send me a copy of the .stl either way, and let me know how it goes!" and "The issue is not something we can fix because it's not an issue in MakerWare. As I suggested, contact Autodesk support and maybe they can help you out!"
Any help?
Solved by JDMather. Go to Solution.
Attach your ipt file here.
Attach your stl file here.
When Save As *.stl click Options and set the correct Units (Inventor defaults to Centimeters).
I once did make the mistake of the stl format by selecting cm instead of mm. The default is in cm.
Hi there! I came upon this is a google search, cause I am experiencing the same problem, but in AutoCAD 2015. I cant seem to find the option when I go to 3DP or export to .stl file to export in inches, not CM. When I open the .stl file in my makerbot software, its scaled as preveously posted in this forum. Is there a different way to export 1:1 in AutoCAD?
Thanks in advance.
In AutoCAD type -dwgunits (with the leading - sign) and follow the command line prompts.
Make sure your document units are the intended units.
Thanks for your response JDmather!
I used the instructed command -dwgunits and followed the prompt. After I did that, i typed 3dp to sent to .stl file, and I'm still experiencing the same thing. Ill attach my dwg file. Any other advise? Am I missing something?
Thanks in advance!
