Inventor Forum
Trim curved sheet metal to conical surface
1 REPLY 1
JJarbeau
492 Views, 1 Reply
Hello
I am drawing a fan wheel. The fan blade is curved intersects the shroud, consisting of two cones. I do not know how to trim the blade to the cones. I tried to "split" the blade at the cones and then "delete face" but then the "Go to flat pattern" section on the ribbon is missing. If I suppress the "delete face" feature the "Go to flat pattern" re-appears.
Please see attached files.
Best regards
1 REPLY 1
CCarreiras
in reply to: JJarbeau
Hi!
If you delete the faces, you will open the solid and you get only a surface, so... no solid, no sheet metal... no flat pattern.
Instead split faces, split the solid: use the cone surface as "Split tool" and select the direction that you want to remove material.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
