Inventor Forum
Trim bend lines on flat pattern
3 REPLIES 3
technolog
621 Views, 3 Replies
I would like to ask if there exist an i-logic rule that would trim the bend lines on flat pattern, so that the plasma does not need to etch the whole line, just the ends of specified length. It would save a lot of machine time / or trimming the lines manually in AutoCAD.
Thank you
Autodesk Inventor 2014 Certified Professional
3 REPLIES 3
johnsonshiue
in reply to: technolog
Hi! I don't think I have a solution for the request. But, I would like to understand the request better. Could you be more specific about trimming Bend Lines. Do you just want to make it shorter? How much shorter? Does it help if you output the Bend Lines in a different layer?
Many thanks!
Software Test Engineer
technolog
Thank you for the reply,
I just want to remove the central part of the bend line and leave short lines on both ends. So that the CNC plasma will etch marks where to put it under the press brake without etching the whole line (which is time consuming)
Sincerely,
Tibor
ic198
This would be a useful fix for me too. Some of our builders use cutting machines so old that if the bend line extends right across the part, the machine assumes it is a cutline and cuts along it. We normally offset the bendline from the part edge by a fixed amount- say 25mm- but technolog's suggestion would work just as well.
Something similar already exists- in an Inventor drawing, Edit View, Display Options, Tangent Edges, Foreshortened produces the effect I'm looking for- but not for bend lines.
