Inventor Forum
Translucent parts
5 REPLIES 5
tmccar
438 Views, 5 Replies
Translucent parts
In Inventor LT, it would be very helpful if some of my parts were tranlucent in appearance. I have  changed the "feature appearance" of the extrusion to Polycarbonate Clear" but it's still at the default grey.
5 REPLIES 5
JDMather
in reply to: tmccar
Can you attach an ipt file here that exhibits this behavior?
pcrawley
in reply to: JDMather
Changing a feature to some kind of clear appearance doesn't make that feature clear.  (Changing to a non-clear appearance should work though.)  To switch to a clear appearance, you need to do it at the part level - not the feature level - but that obviously affects everything.
There are ways to make some features have a different appearance by creating those features as a different body (as in "multi-body solids").  Each body can have a different appearance - and translucency is respected (until you derive it into another part...)
I did once see a hack/workaround to creating a snow-globe model where the globe was glass and the base was wood, but the technique was a bit of "smoke and mirrors" at best.  Suggest you stick with multi-body solids.
Peter
tmccar
On the attached .ipt file, the properties of the square block are set to "clear - light"
JDMather
in reply to: tmccar
@tmccar wrote:
... if some of my parts were tranlucent in appearance.....
It appears that you are attempting to make an assembly of multiple parts in a single part file.
To do that you need to select New Solid option when doing a Extrusion (or other feature).
You can then set the Properties of the individual solid bodies.
There are several other basic problems with your part, including -
unconstrained sketches, a sick sketch, axis that is duplication of origin axis, workplane that is not needed...
I will try to post an improved technique later today.
tmccar
OK, I have tried creating new solids, and it works - thanks.
