Inventor General
*Expert Elite*
JDMather
Message 11 of 18 (460 Views)
Re: Translational/Rotational constrain for pin in slot.
08-15-2008 12:03 PM in reply to: Jason.Taylor
> I don't think that I have over constrained the model
It is over constrained - delete the tangent constraint as instructed.
>The only problem is that the pin doesn't stay within the perimeter of the slot.
If you drive constraint it should stay within the slot. If you try to drag with the mouse Inventor cannot keep up with the calculations.
>Can't open it. I am using INV 08'.
Always state what release you are using when not using the latest release.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
mcgyvr
Message 12 of 18 (460 Views)
08-15-2008 12:32 PM in reply to: Jason.Taylor
Put a driven constraint on the door angle and use that to move it not the mouse as JD suggested.
I've attached an image showing all that is required for the trans constraint
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Active Member
Jason.Taylor
Message 13 of 18 (460 Views)
08-15-2008 01:45 PM in reply to: Jason.Taylor
WOW... Sorry to waiste everyone's time! I pulled the parts out of my top level assembly and assembled a smaller version (file size) of the enclosure and it worked perfectly (as long as I used one of the arms on the door retainer to adjust the door level)! I guess my rig isn't strong enough to handle the detail that i have on the top level assembly. Sad that it took me half a day to figure that one out!
Thanks for your help fellas!
*Expert Elite*
JDMather
Message 14 of 18 (460 Views)
08-15-2008 02:16 PM in reply to: Jason.Taylor
Assuming you will place that hinge assembly as two instance of a sub-assembly make sure you right click on the sub and set it to Flexible.
Active Member
Jason.Taylor
Message 15 of 18 (460 Views)
08-15-2008 02:21 PM in reply to: Jason.Taylor
That is news to me! Thanks for the tip! I actually inserted each piece seperately because I didn't know the function "flexible". I will use that one in the future!
Thanks again,
*Expert Elite*
JDMather
Message 16 of 18 (460 Views)
08-15-2008 02:32 PM in reply to: Jason.Taylor
You can Ctrl right click on the parts and Demote to a sub-assembly. Might speed things up.
Active Member
Jason.Taylor
Message 17 of 18 (460 Views)
08-15-2008 02:51 PM in reply to: Jason.Taylor
I tried that but the assembly with the pin and slot didn't "move" or rotate appropriately. I used the Flexible function. What gives?
New Member
wjc44646
Message 18 of 18 (163 Views)
02-08-2013 09:36 AM in reply to: Jason.Taylor
Had same problem. Don't know a lot about inventor just getting used to it.  But if you re-extrude your slot holes again with a surface instead of solid, that worked.  The surface button is in the lower left of the extrude pop up box.  It looks lik a hollow box and when you hover over it it says surface. Good luck.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
