Had same problem. Don't know a lot about inventor just getting used to it. But if you re-extrude your slot holes again with a surface instead of solid, that worked. The surface button is in the lower left of the extrude pop up box. It looks lik a hollow box and when you hover over it it says surface. Good luck.
