Inventor Forum
Transitional Constraint question.
2 REPLIES 2
Wez87
243 Views, 2 Replies
Hello all,
I have a question regarding a transitional constraint between a pin and a surface within an adaptive assembly.
I would like the pin and the surface to be transitional only when the two parts "interfere" with each other.
At the moment with the example attached part A is remaining tangent to part B, restricting the necessary movement of part B to function properly in the mechanism.
In simplified terms I need part B to be able to break free of the "transitional constraint" of part A under certain movement conditions within the mechanism.
Is what im suggesting possible?
Any help would be much appreciated.
Best Regards
Dale
2 REPLIES 2
Curtis_Waguespack
in reply to: Wez87
Hi Wez87,
The file you attached is an empty assembly file. We'll need the part files also, in order to be able to see your geomtery. If you're having trouble attaching files, you might try adding screen shots as well.
I hope this helps.
Curtis
Wez87
in reply to: Curtis_Waguespack
Hi there,
My appologies here is the is the .iam with parts.
Many thanks.
Regards
Dale
