HI,
My company recently upgraded to Inventor 2012 from 2011. I had a couple drawing templates that contained some different styles than that of the default template. I was able to do this before by changing "Use Style Library = No" in the project settings previously, but this option has been removed in 2012. Is there any way I can Achieve this in 2012?
I don't seem to see a place to import a STYXML file. Is there any way I can either update the default to the styles in the STYXML file or use the styles located in the template by default?
Thanks.
This is precisely what the style library is for. It's a repository for all your styles, and can be set up with multiple different standards. We have three: Inch, dual dimension, and metric. We have two templates, inch and metric. The inch template uses the inch standard by default, but can be switched to dual; the metric template uses the metric standard by default.
Styles and style libraries can be difficult to get your head around, but once you do, they make life so much simpler.
