Inventor General
New Member
Message 1 of 3 (688 Views)
To be able to twist and sweep a profile along a spline
688 Views, 2 Replies
05-14-2012 01:29 AM
                     I am quite new to the inventor society and am stuck on a problem. My task is to model a twisted rope and for that i need to twist and sweep a certain profile ( please see attached jpg for a rough idea of the profile ) at the same time along a spline path. Inventor is unable to accept the spline path as axis for a coil feature.
                      One possible solution was to use sweep with a guide rail , and for the guide rail we would have to use a helix wrapped around said spline.
                       Can anyone suggest a method to either simultaneously sweep and twist a profile, or to be able to wrap a helix around a spline in inventor? I have attached a picture of the required helix too.
Thank you in advance for any replies,
Srinath
*Expert Elite*
Message 2 of 3 (676 Views)
Re: To be able to twist and sweep a profile along a spline
05-14-2012 03:26 AM in reply to: SrinathSibi
I would use a texture rather than actually model the twisted tri-lobe.
By the time you back up a bit it will look the same.
Much easier and smaller file size.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
*Expert Elite*
PaulMunford
Message 3 of 3 (640 Views)
05-14-2012 05:55 AM in reply to: SrinathSibi
I don't think that you can helix around a spline in Inventor, I would be happy to hear from anyone who knows how!
For this model, how about patterning a workplane along the spline, and then using a sketch block for the profile. You will need to set the rotation of the sketch block manually in each case. Finally you can loft between the sketches to get your rope.
Let us know how you get on :smileyhappy:
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
