Inventor Forum
Tittle block and paper size
10 REPLIES 10
Message 1 of 11
255 Views, 10 Replies
I'm wondering if most of you here create different title blocks for diff.
paper sizes or just one title block for all paper sizes?
Thx
IV10 Pro. SP2
Window XP Pro sp2
Pentium 3.2 Ghz, 3.0 GB of RAM
NVIDIA FX 3400 7.1.8.4
10 REPLIES 10
Message 2 of 11
R.Corriveau
One size.
Some customers have different title blocks for assemblies and details though.
Message 3 of 11
I have one title block for all papaer sizes here (actually 2, depending
on which customer the design is for), but I only use larger paper sizes.
Out current title block would take up half the paper if I tried to put
it on a letter size sheet (A), but I have used it down to B size OK.
> Thx
Message 4 of 11
Well ... it's trouble me 'cause I use .125 (text size) for B-, .156 for C-,
.200 for D- and .250 for E- sizes.
"Chris (IV10 Pro. SP2)" wrote in message
news:4987921@discussion.autodesk.com...
Thx
IV10 Pro. SP2
Window XP Pro sp2
Message 5 of 11
R.Corriveau
Ya. We rarely even use C. Mostly D & E
Message 6 of 11
hallstevenson
> for C-,
We used to do that too.... (not anymore)
I took the included titleblock and tweaked/modified it to match our standard titleblock very closely. Everyone's happy with it and realize it might not be EXACTLY like our AutoCAD one. It works for B, C, and D size. Haven't tried anything bigger. It does NOT work for A size.
Message 7 of 11
Included titleblock: you mean ANSI-large?
wrote in message news:4987934@discussion.autodesk.com...
> for C-,
Message 8 of 11
We just use B and D and we do use the same title block for both. But you
could make different ones and then assign a Sheet format to each paper size
to pull in the correct title block.
IV9 SP4
Rodney
Thx
IV10 Pro. SP2
Window XP Pro sp2
Message 9 of 11
Different for each size. We use an architectural style that spans the height
of the sheet.
Message 10 of 11
Squeezer
I used to have 4 (A, B,C&D) but I have cut it back to 2 one for A or B and the other for C&D. Much of what we do is printed on 11X17 for review & hard copy storage (yes, we stll do that) regardless of the original paper size so I needed to use a larger font on the larger sizes.
Our defualt idw template is preset to use our most frequently used idw size which is "D".
Message 11 of 11
We have two, a small one for A & B, the larger one for everything else.
Like Squeezer, we mostly print to 11x17, so the larger fonts are needed for
the larger sheet sizes.
Sam
Eli Lilly and Company, Indianapolis
Thx
IV10 Pro. SP2
Window XP Pro sp2
