Inventor Forum
Title Block Question
2 REPLIES 2
brandonherrer14
460 Views, 2 Replies
Dear Forum,
Really quick question...
When i make a drawing in inventor, in the Title Block, it says the title of the saved document in the Drawing No. section. So what i am saying is how do i get the title of the saved document out of the drawing number section and either delete it or get it in the Title section.
Thank You,
Brandon
2 REPLIES 2
Hi brandonherrer14,
It depends on how your title block is set up, but if you right-click on the top node in the browser of your drawing and choose iProperties, you can look on the Project tab for the Part Number field. If you see the offending text there, then just delete it and all should be well.
But if it's not there then you will want to open the model and right-click on the top node in the browser and choose iProperties. Then look on the Project tab for the Part Number field and remove remove/change the part number as needed.
Basically your title block reads information form the iProperties of either the drawing itself or the model that you place in the drawing.
I hope this helps.
Curtis
Your great. Thank you for all your help.
Best of Luck,
Brandon
