Inventor General
Active Contributor
brandonherrer14
Message 1 of 3 (259 Views)
Title Block Question
259 Views, 2 Replies
06-06-2012 03:26 PM
Dear Forum,
Really quick question...
When i make a drawing in inventor, in the Title Block, it says the title of the saved document in the Drawing No. section. So what i am saying is how do i get the title of the saved document out of the drawing number section and either delete it or get it in the Title section.
Thank You,
Brandon
Curtis_Waguespack
Message 2 of 3 (257 Views)
Re: Title Block Question
06-06-2012 03:36 PM in reply to: brandonherrer14
Hi brandonherrer14,
It depends on how your title block is set up, but if you right-click on the top node in the browser of your drawing and choose iProperties, you can look on the Project tab for the Part Number field. If you see the offending text there, then just delete it and all should be well.
But if it's not there then you will want to open the model and right-click on the top node in the browser and choose iProperties. Then look on the Project tab for the Part Number field and remove remove/change the part number as needed.
Basically your title block reads information form the iProperties of either the drawing itself or the model that you place in the drawing.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Contributor
brandonherrer14
Message 3 of 3 (246 Views)
06-06-2012 05:43 PM in reply to: Curtis_Waguespack
Your great. Thank you for all your help.
Best of Luck,
Brandon
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
