I am using 2013 Inventor.
* My company uses the .dwg file extension instead of .idw (if that makes a difference).
When I make a new .dwg file and insert an .ipt file for my first base drawing . . .
When I open iProps in the .ipt drawing and go to the Physical/Material Tab . . .
My company chooses to give all material specs in a note displayed on the drawing.
Who can help me with this?
Thanking you in advance, I am,
CADManTom
Hi cadmantom,
I think you'll want to edit the title-block definition and change the material field so that it doesn't look at the model iProperties. You can set it to use a prompted entry (manual input) or set it to look at the drawing's iProperty set.
Also, you can set your standard notes to read in the model's material iProperty, so that you don't need to change it manually in the drawing, if that helps.
I hope this helps.
Curtis
