Mike
You should be posting in one of the normal Inventor NG's such as Inventor.6. This is NG
is for writing macro's and such. I will send this in to be moved there.
It all depends on how your titleblock is set up. If it is set to use file properties then
it should show in your titleblock.
When creating a custom titleblock do it in your template file so that it is always
available in new drawings. To add it to existing drawings, open both the existing and the
template. Make sure there isn't a titleblock in the existing with the same name (delete
it if necessary) then in the template go to the browser and expand the folder and right
click on the titleblock name. Select copy ... go to the existing file and right click on
the titleblock folder and paste.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Mike Drabic" wrote in message
news:5D0CC0FA57B946F50F3712894BE52A84@in.WebX.maYIadrTaRb...
> The information in the file properties pull-down is not showing up in my
> title block.
> Also, when creating a custom title block where is that saved, because I
> cannot find it in the progam files.
> thank you
> mike
