Inventor Forum
Tips and tricks for creating an exploded view
4 REPLIES 4
ClintWestwood
1036 Views, 4 Replies
I am working on pulling apart a large (300+ parts) assembly, and Inventor's presentation environment just seems way too clunky for me. The "Tweak Components" command seems very limited, and I am spending most of my time going through and clicking on individual parts. Once I finally select all the parts I want moved, I move them and then realize that I missed a screw or something small, and I have to go back and fix it.
Maybe I'm not the only one with these frustrations, or (most likely) maybe I'm doing it the hard way. Does anyone have any good suggestions or tips for working with Inventor's presentation environment?
Inventor 2014
HP Pavilion dv6t-6b00
Intel Core i7 2670QM
AMD Radeon HD 6490M
16gb RAM
Windows 7 64 bit
3Dconnexion SpaceExplorer
4 REPLIES 4
blair
in reply to: ClintWestwood
I do use the "Sort Components" in the IAM file. This at least sorts parts in the Browser by Part Number. It does help with selecting the components but it's clunky at best.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Hi ClintWestwood,
One tip that you might or might not already be aware of, is to change the browser view to Tweak View or Sequence View, and then you can add components to the tweaks you've already created, as well as move components from one tweak action to another, or change the order of tweaks:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-5BBEA4A5-452D-4676-8D16-40E503FBE846
The other thing I find myself doing a lot is selecting all of the components I want to tweak, then creating the first tweak by dragging them all in the direction of the tweak, then hold the CTRL key to remove one component (that I want to "leave behind"), then drag the rest to create the next tweak, then then hold the CTRL key to remove then next component, then drag the rest to create the next tweak, repeat and rinse, etc. ...
I hope this helps.
Curtis
rdyson
Picking sub-assemblies in the browser will select all the subs parts
PDSU 2016
Thanks for the suggestions, everyone. I especially like the Tweak View in the browser which allows me to change the distances of my previous "tweaks". I still think the presentation environment is much more clunky than it could be, but I will learn to live with it I guess.
Inventor 2014
AMD Radeon HD 6490M
16gb RAM
Windows 7 64 bit
