This is a belated thanks but thank you very much for the time stamp.
Lester
Kent,
I downloaded this as well and I know this will help me a lot. But I don't know if it downloaded wrong or not. I have Inventor 2013 64 bit. It seemed to install fine and created a tab in Add-Ins. When I go to Add-Ins and click on KWik Time Stamp I only got one box, the TimeStampsSettings box. I do not get the box you list here (copied from your webiste) to position it on the drawing.
"The combo box dropdown, allows you to select your Locale. The bottom Text box allows you to select your own name for the custom iProp that gets generated at every save. Simply reference that iProp anywhere you want to add a Save Time Stamp."
Thanks so much!
