Inventor General
Active Member
ihracska
Message 1 of 2 (154 Views)
Tickhen command failing
154 Views, 1 Replies
11-19-2012 06:37 AM
Hi all,
I have two very similar and fairly simple surface models. I’ve been trying to convert them to solids using the Thicken/Offset command. It worked just fine with one of them but no result with the other one and I don’t understand why it has worked fine in one case but not in the other. I’ve tried to change the direction and give different thicknesses but I only got  error messages. I’d be grateful if someone explained.
Files attached.
Alexis
Cadmanto
Message 2 of 2 (126 Views)
Re: Tickhen command failing
11-19-2012 11:13 AM in reply to: ihracska
Alexis,
I opened up both of them and could not quickly figure out the exact issue, but the thought that came through my mind was why not do a copy design of the one that worked and tweak that one.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
