Solved by tlebrun. Go to Solution.
Is there (will there ever be) an option to make the threads ON as default? (even if I have to use regedit) [for views of assembly models]
If I understand correctly, current versions (the original post was concerned with Inventor 2008) will maintain the options that were checked when a view was last placed. This is per view type, so placing a Base view will maintain options separate from placing a Section view, for instance. But the option needs to be set when placing the view and will then be the default for every Base view (for example) placed after that. This is maintained indefinitely, until a view is placed with a different option.
Hope that helps you. The OP probably doesn't care anymore...
Sam B
Inventor Pro 2022.2.2 | Windows 10 Home 21H2
