Inventor General
Employee
udayag
Message 11 of 21 (858 Views)
Re: Threaded holes option is unselectable
04-22-2011 10:53 AM in reply to: udayag
Sorry, there was a typo:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion 15.0\System\Preferences\Part
Udaya Gunasena
Fusion Development
Active Member
cfn101788
Message 12 of 21 (847 Views)
04-22-2011 11:35 AM in reply to: udayag
I understand this is for Inventor 2011. But I am using Inventor 2012 and in the registry the file named "Part" does not exist. Thus there is no registry key labeled "UseExcelToReadThreadFile" for me to edit. If all the registry files for Inventor 2012 should be the same as Inventor 2011 then I am missing about 10 of them.
Employee
udayag
Message 13 of 21 (837 Views)
04-22-2011 11:52 AM in reply to: cfn101788
Is it possible that Inventor 2012 was not installed properly?
Udaya Gunasena
Fusion Development
Active Member
cfn101788
Message 14 of 21 (833 Views)
04-22-2011 12:01 PM in reply to: udayag
I may have to reinstall it then. Not sure what happened during the install. I have to wait for the admin to come back from vacation before I can perform an uninstall/reinstall. It seems that the fix is changing the registry value. I will update on teh outcome when I am able to reinstall it.
Employee
udayag
Message 15 of 21 (828 Views)
04-22-2011 12:10 PM in reply to: cfn101788
If you are reasonably comfortable editing the registry you could try the following:
1. add (RMB and select New) a key called "Part" under "Preferences"
2. add (New) a DWORD (32 bit) called "UseExcelToReadThreadFile" with a decimal value of 1.
Udaya Gunasena
Fusion Development
*Pro
Message 16 of 21 (822 Views)
04-22-2011 01:35 PM in reply to: cfn101788
I have it in the same localtion in XP Pro for 2012 under CURRENT_USER
By chance are you looking in LOCAL_MACHINE instead?
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Active Member
cfn101788
Message 17 of 21 (812 Views)
04-22-2011 03:21 PM in reply to: Dennis_Jeffrey
I went through every File in the registry and it wasn't in any of them. Pretty sure Inventor did not download correctly. I added the registry key for the threads option and I am able to use the thread option now. We'll see how far that gets me since I am missing a bunch of other registry files. Ill likely have to do a reinstall to get them all.
Employee
Message 18 of 21 (783 Views)
04-26-2011 12:43 AM in reply to: cfn101788
If it's the first run of Inventor with current user account, the full registry (HKCU\Software\Autodesk\Inventor\RegistryVersion16.0) should be finished after closing Inventor. I tried wtih a new standard user account, ...\Preferences\Part key appears after closing Inventor.
Jar Fu
SW Engineer
Inventor QA
Autodesk, Inc.
New Member
DennisArmstrong4475
Message 19 of 21 (525 Views)
12-21-2011 07:24 AM in reply to: cfn101788
Using the regedit did work for me, however, I could not have Inventor open while I edited the registry. As soon as I closed it, it went back to value of 0. So I closed Inventor, edited value to 1, reopened Inventor... and success.
Thanks for the help!
New Member
Message 20 of 21 (388 Views)
05-01-2012 06:52 AM in reply to: udayag
This worked for me as well.
Thanks!
XP-SP3
Inventor 2012
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
