It's a bit worrying that installing SP1 can over-writes a customised Thread.xls
file without backing it up :-(
Many users will have customised Thread.xls without knowing this. I'm surprised
Adesk feel the need to over-write the thread file whilst installing a Service
Pack.
Has this been documented ?
For the time being users will have to make their own back-up, but Adesk should
really improve their act.
Duncan
[Monday morning moan is over]
"Udaya Gunasena (Autodesk)" wrote in message
news:40f84f4d$1_3@newsprd01...
> Just to clarify further...
> There are two kinds of thread families (each sheet or tab in the file
> corresponds to a thread family): parallel threads and taper threads.
> You can easily tell them apart. Parallel familes will have "inch" or "mm" in
> cell A1, and taper families will have "inch-taper" or "mm-taper" in the same
> cell (non-English locales will have corresponding translated strings). If
> you try to create a tapped hole you would see only parallel threads, but for
> thread feature both types are shown.
> "Bob Van der Donck (Autodesk)" wrote in
> message news:40f84bf6$1_1@newsprd01...
> > Gary,
> > In order to get access to NPT threads, you need to have a "Pipe" (as the P
> > in the NPT implies) and apply the "Thread" command.
> > I would also like to advise to restart Inventor after changing data in
> > thread.xls. Just to be sure that your modified data and not the old data
> is
> > loaded.
> > Bob
