BTW, there is another problem with threads:
Let take ISO metric standard.
We have one assembly where M20x1,5 thread goes through couple of parts (manufactured at assembly itself)
Both parts do already have plain 18,5mm dia holes (as supposed).
Inventor (up to release 2012) refuses to build thread in the assembly (the feature didn't change the number of faces...) unless diameter be <=18.376mm (even so Tap drill diameter is 18,5mm).
Isn't that something that should be improved?
We use feature recognition software here, and when inventor refuses to model something correctly, we are forced to hand-program (when we catch it) the feature for our CNC's. Pipe threads are typically used here for grease zerks and some other lubrication features. This is a very frustrating flaw in Inventor. Even modifying the thread.xls file is difficult; The parameter(s) that drive the feature are absolutely ludicrous.
After changing values in the thread table, one column at a time, and re-starting inventor repeatedly (to purge the cached thread table), I have finally identified the parameter that needs changed when you correct the tap drill diameter. If you change this value by the same amount as the tap-drill change, it appears to properly generate the feature in the model. I have only done the 1/8 NPT so far (as that is the one I need on this model), but I'm sure this will help those others having this same issue.
I used a slightly tweaked "wrench makup diameter" then described above so the bottom of the taper is nearly the same diameter as the tap drill.
why would "Wrench makeup" have anything to do with modeling this feature. Do I have some ignorance that's preventing me from seeing the correlation? If this is the case, please, someone fill me in.
It's unfortunate that Most Machine Designers are not computer programmers/and computer programmers are not machine designers. This is fairly evident in inventor.
By default: C:\Users\Public\Documents\Autodesk\Inventor <version>\Design Data\XLS\en-US
Mark Lancaster
& Autodesk Services MarketPlace Provider
@cadcamm99 wrote:
where is the table located?
@cadcamm99 Its located in the XLS folder where your design data/style library stuff is..
@mcgyvr Too slow today...
Mark Lancaster
But thats not where my thread file is.. and many others I'm sure..
Lets be like power rangers and combine to be one super power..
Mark..
+ Me
+ A little extra
That can be found by looking at your project file settings..
= Super Answer...
The thread taper however still wants to go to the .422 dim making the thread length small. According to Inventor the taper length should be .395. But after changing the drill size to .4375, the length is smaller even though Inventor shows it at .395.
