Inventor Forum
Thread checking tool- a way to measure thread data
18 REPLIES 18
Message 1 of 19
3849 Views, 18 Replies
Is there an Add-In or some other way I can get Inventor to quickly show me what the thread data is for a threaded hole? Currently, I have to edit the feature, to be able to read that the hole is a certain thread size. There should be an option in the measure command that allows this. We have measure, angle, area, loop, but no thread ID.
This should really work for all types of threads: holes and external treads, of course they would have to be modeled in inventor, not imported parts.
This becomes a major waste of time, when you are in upper level assemblies and you are placing fasteners into the assembly. You have to drill down to the part level, or change to feature selection, and edit the individual feature.
Joe
Inventor 2012
18 REPLIES 18
Message 2 of 19
Mike_Maenpaa
Try the Rename Browser macro at http://www.kwikmcad.com/icode/macros/macros.aspx
Mike
Message 3 of 19
IV 2012 does its almost automagically... Set it in Application Options >> Assembly tab.
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Message 4 of 19
in reply to: Dennis_Jeffrey
These solutions still require drilling down to the part level. A measure tool would work the best.
And since I have everyones attention, the "show dimensions" on a tapped hole should show the thread data, not the tap drill diameter.
Joe
Message 5 of 19
Dennis_Jeffrey
How would you use a measure tool? The threads are a cosmetic image. The setting I showed is a manual setting that then applies to all files.
"be able to read that the hole is a certain thread size. There should be an option in the measure command that allows this. We have measure, angle, area, loop, but no thread ID."
Message 6 of 19
rdyson
Actually Tuen Han (someone please correct my spelling) wrote an addin a few years ago that did exactly what you want (I think)
You might be able to search and find it. (after someone tells you hoew to spell his name)
It will probably need updating, especially for 64 bit
PDSU 2016
Message 7 of 19
IgorMir
   Similar to how the thread ID is called out in the drawing. You click on the face which has some thread associated with it and get the info. Not what you have suggested originally. (To look in the browser instead).
Igor.
Web: www.meqc.com.au
Message 8 of 19
Dennis_Jeffrey
in reply to: IgorMir
Yes, that's another way. I was assuming he wanted the info from the model, not the drawing.
Message 9 of 19
IgorMir
No Dennis, it is not another way. The OP is asking for getting the thread info from the model, not in the drawing. And this functionality is not available in Measure tool yet. It is not a major show stopper for me, but just to keep the record straight...
Igor.
Message 10 of 19
jalexander
I agree.  The measure tool should be able to tell you the thread size since the thread size has been defined in the model itself, even though it is only an image.  It would show you the size of the thread from within the model, without drilling down into the browser or changing from "Assembly" browser view to "Model" browser view or both.  When in the the drawing environment, Inventor can find this intormation, why can't the measure tool do the same from within the assembly or part environment?  I'm not sure how difficult it would be to write the code, but I know it can be done: where there's a will, there's a way.
Message 11 of 19
Loren_J
in reply to: jalexander
Set the selection filter to Feature and double-click on the hole. The Hole dialog opens and shows all the data. Press Esc when you are done.
LorenJ
Inventor 2011 Pro
Win7 64 SP1
Xeon W3550 @3.07 GHz
ATI FirePro V5700, 8.773.0.0
12 GB RAM
Message 12 of 19
SBix26
in reply to: Loren_J
So, now that many of us agree that this would be a very useful enhancement to the Measure tool, who is going to add it to the wish lists?
Message 13 of 19
IgorMir
in reply to: SBix26
What for? Just to top the list up to 10000001 entry?LOL!
Igor.
Message 14 of 19
kstate92
in reply to: SBix26
Coming from a 'Made Guy' (well known expert or developer), it might get some attention, but from a handful of users?  We'll see.
It still feels troubling that there is not an official official (hosted by Autodesk) Wish List, but just a few lists hosted on CAD forums here and there.  Out of sight, out of mind strategy, perhaps?
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
Message 15 of 19
ollieboy23y
in reply to: rdyson
Has anyone found the addin?
Message 16 of 19
JelteDeJong
in reply to: ollieboy23y
you could save this as an external iLogic rule. it will show the thread info of tapped holes in assemblys. (If you manage to select a  ThreadFeature then it will do the same.)
Dim msg As String = ""
Dim Feature As PartFeature = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFeatureFilter, "")
If (TypeOf Feature Is ThreadFeature) Then
    Dim threadFeature As ThreadFeature = Feature
    Dim tapInfo As ThreadInfo = threadFeature.ThreadInfo
    msg = msg & "ThreadDesignation: " & tapInfo.ThreadDesignation & Constants.vbCrLf
    msg = msg & "ThreadType: " & tapInfo.ThreadType & Constants.vbCrLf
    msg = msg & "Class: " & tapInfo.Class & Constants.vbCrLf
    msg = msg & "RightHanded: " & tapInfo.RightHanded & Constants.vbCrLf
    msg = msg & "FullTapDepth: " & tapInfo.FullTapDepth & Constants.vbCrLf
ElseIf (TypeOf Feature Is HoleFeature) Then
    Dim hole As HoleFeature = Feature
    If (hole.Tapped) Then
        Dim tapInfo As HoleTapInfo = hole.TapInfo
    Else
        msg = "Hole is not tapped!"
    End If
Else
    msg = Feature.Name & " isnt a threaded feature."
End If
MsgBox(msg, MsgBoxStyle.OkOnly, "Tap info")
Jelte de Jong
Blog: hjalte.nl - github.com
Message 17 of 19
Ray_Feiler
in reply to: JelteDeJong
FYI, if the feature selected is a patterned tapped hole you get this message.
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 18 of 19
JelteDeJong
in reply to: Ray_Feiler
@Ray_Feilertnx for the comments.
i changed the code it now also shows the information about patterns
Sub Main()
			msg = getTapInfoString(tapInfo)
		Else
		End If
	ElseIf (TypeOf Feature Is RectangularPatternFeature) Then
		Dim pattern As RectangularPatternFeature = Feature
		msg = "Pattern '" & Feature.Name & "' contains the following holes:" & Constants.vbCrLf & Constants.vbCrLf
		For Each patternFeature As PartFeature In pattern.ParentFeatures
			If (TypeOf patternFeature Is HoleFeature) Then
				Dim hole As HoleFeature = patternFeature
				msg = msg & patternFeature.Name & " is a hole with the following thread: " & Constants.vbCrLf
					msg = msg & getTapInfoString(tapInfo)
				End If
				msg = msg & Constants.vbCrLf
			End If
		Next
	ElseIf (TypeOf Feature Is CircularPatternFeature) Then
        Dim pattern As CircularPatternFeature = Feature
                End If
            End If
        Next
	Else
		msg = "Selected feature isnt a threaded feature"
	End If
End Sub
Function getTapInfoString(tapInfo As HoleTapInfo) As String
    Dim msg As String = "ThreadDesignation: " & tapInfo.ThreadDesignation & Constants.vbCrLf
    Return msg
End Function
Jelte de Jong
Message 19 of 19
Ray_Feiler
Perfect! 😀👍
