Anybody get this plugin to work with 2013? I keep getting the dialog saying: Failed to create CoilFeature... Try with a bigger Pitch Offset value.
I have tried the suggestion but it still does not work for me.
Rob
Solved by drlamb. Go to Solution.
Solved by RobJV. Go to Solution.
Tried it on a 1/4" bolt and it works so not sure what parameters keep it from working on random threaded features.
Rob
I just got it to work with a #4 screw. Are you picking the thread feature in the browser?
The app may not run on sheet metal parts. I was experimenting on a sheet metal part and decided to convert to standard part and now it works.
Rob
I see why. It converts it to a multibody solid. I knew I had run into it before. You can work around it but it's a pain.
