Inventor General
ryan.sanderson
Message 1 of 6 (236 Views)
Thickening parts
236 Views, 5 Replies
12-24-2011 08:23 AM
Hi
I've created the following part, its a turbine prop, I've created the blade and have extruded the centre. On thickening the blade surface, due to the angle of the blade there is some parts of the blade which appear to start in mid air(the edges), does any one know how this can be blended in with the hub?  The surface which I created to begin with perfectly fits around the hub, its only when thickened does the edges come away from it. I could thicken in another direction to hide the problem but Id like to know for now and future use how/ if there is a way to fix this issue, I've also tried surface extend but it doesn't like it.
Cheers
Ryan
JDMather
Message 2 of 6 (232 Views)
Re: Thickening parts
12-24-2011 10:12 AM in reply to: ryan.sanderson
I noticed that you are not constraining sketches -  yet have perfect dimensions if I add the missing dimensions?
How are you doing that? Why? Are you erasing dimensions?
It looks to me like you are doing too much work.
Two simple 2D sketches will create the 3D sketch boundary for a Boundary Patch (or Loft if desired) that can be Lengthened.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
ryan.sanderson
Message 3 of 6 (223 Views)
12-24-2011 01:05 PM in reply to: ryan.sanderson
Thanks for the reply, appreciate it.
The drawing has been created from many different calcs which were then plotted. I'm not sure the two drawing method would capture all of the angle changes within the blade but it might I will deffo barely check that out!!
I normally delete measurements to make viewing it easier, I don't use it that often so I'm lacking a bit of knowledge in sing it to be honest.
Have you thickened the part you made? And then tried extending it into the hub? That's where I become stuck, it wont let me extend the surface of the loft into the hub or extended a thickened part either.
Cheers
Merry Christmas Ryan
ryan.sanderson
Message 4 of 6 (221 Views)
12-24-2011 01:30 PM in reply to: ryan.sanderson
Checked that, the two drawins great! Saved me hours of work, still issue with the gaps on the hub when thickened.
ryan.sanderson
Message 5 of 6 (220 Views)
12-24-2011 01:33 PM in reply to: ryan.sanderson
Sorted, many thanks
JDMather
Message 6 of 6 (217 Views)
12-24-2011 01:40 PM in reply to: ryan.sanderson
You can right click on a sketch and turn off Dimension Visibility when you exit the sketch to clean up the screen.
I checked my simplified model against your complex model and there was only slight difference at the top which could be made  closer by using an arc rather than a line - but it looked to be well within any reasonable manufacturing tolerance so I left it as a line for the boundary.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
