Greetings and a happy new years to all you good folks.
I am using surfaces for the first time and have hit a snag. But first:
I have lofted 3 sketches using guide rails, each of the 3 rails consists of 2 or more arcs. The only way I can use them is to project points onto a new sketch and create a spline. Is this correct?
My plan is to sweep the handle from its farthest point right through the scoop, and then use the surface as a split tool. It worked for "spoon 2013" but when I try to thicken/offset the scoop I get the front edge trying to thicken in the wrong direction. I then noticed an unconstrained sketch, So I back tracked "spoon 2013 II", re-drew the broken sketch, but to no avail!
Any help or advice on a better way to approach this form will be much appreciated
- Inventor Pro 2013
I would not try to model the scoop to it's finished size in one Loft.
Model the surface oversize and then trim back to desired finish size.
The CADWhisperer YouTube Channel
Ah-ha, so just like in "real life" then.
I'll extend my perimeters and guide rails and take it from there.
Thank-you JD
In my ever-continuing learning process I now see that I can use "bridge curve" as an alternative to creating a spline to define a guide rail.
