Inventor Forum
Thicken Sheet Metal parts
1 REPLY 1
frisbdave
526 Views, 1 Reply
I have used the thicken command on a sheet metal part
Will the flat pattern be adjusted to take into account the sheet thickness being different from that specified by the "thickness" variable, or will the flat pattern be incorrect?
1 REPLY 1
ToH
in reply to: frisbdave
As you described it here, the plate thickness may differ. When you use the thicken command set the thickness = parameter 'Thickness'. Then you control everything from the sheet metal style
