Show only
Search instead for
I have used the thicken command on a sheet metal part
Will the flat pattern be adjusted to take into account the sheet thickness being different from that specified by the "thickness" variable, or will the flat pattern be incorrect?
As you described it here, the plate thickness may differ. When you use the thicken command set the thickness = parameter 'Thickness'. Then you control everything from the sheet metal style
