Inventor General
*Dotson, Sean
Message 1 of 14 (60 Views)
The little things
60 Views, 13 Replies
12-08-2002 11:47 PM
This is one that I've grumbled to myself about for some time now but keep
forgetting to see if it annoys everyone else.
When selecting a part/assy/presentation to insert into an IDW why do we not
have a "All Inventor files" option in the file selection dialogue. Many
times I've navigated to the correct folder not to find the part I want.
Then (sometimes after checking that it is indeed in the folder via Explorer)
I go back to the dialogue to notice it's set to IAM files...
If we could list the all then we could filter them later if necessary...
Just me?
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
*Maenpaa, Mike
Message 2 of 14 (60 Views)
Re: The little things
12-08-2002 11:50 PM in reply to: *Dotson, Sean
I agree. I've grumbled about the same thing. First choice should show all
file types to choose from.
Mike
"Sean Dotson" wrote in message
news:FBAE33D4621991594C4827F8A4D3DA2F@in.WebX.maYIadrTaRb...
not
Explorer)
> Just me?
> Sean Dotson, PE
Distinguished Contributor
MechMan_
Message 3 of 14 (60 Views)
12-08-2002 11:51 PM in reply to: *Dotson, Sean
I agree. If I want to see everything in the directory I've just gotten used to typing in *.* to see everything. I deem an "All Files" option a necessity in this dialog box.
MechMan
*Harvey, Paul
Message 4 of 14 (60 Views)
Re:
12-08-2002 11:58 PM in reply to: *Dotson, Sean
Agreed. ALL files should be the default
MO.
I
typing in *.* <Enter> to see everything. I deem an "All Files" option a
MechMan
*Jaquith, Walt
Message 5 of 14 (60 Views)
12-09-2002 12:05 AM in reply to: *Dotson, Sean
> Just me?
Nope. Me too.
WJ
*Laimer, Leo
Message 6 of 14 (60 Views)
12-09-2002 12:49 AM in reply to: *Dotson, Sean
Just and addition to this:
Why not have some huge buttons along the upper or lower rim of the file-open
dialogbox, with similar icons like new part file / new assy file / new idw
to get the filter set to the appropriate filetype?
I see myself reading the entries in this tiny dropdown and scrolling down to
other entries, again and again, all day long....
And, please, make that dialogbox HUGE, minimum 21" wide, full screen! My
recent project has 600 parts, means about 1500 files altogether! The
scrollwheel is already worn out !
Leo Laimer
Maschinen- und Fertigungstechnik
A-4820 Bad Ischl - Austria
"Sean Dotson" schrieb im Newsbeitrag
not
Explorer)
> Just me?
> Sean Dotson, PE
MechMan_
Message 7 of 14 (60 Views)
Re:
12-09-2002 01:22 AM in reply to: *Dotson, Sean
I like your part type idea as icons on the main window. Another trick. In the Open dialog box highlight the first file and then start typing in the file name you're looking for and the dialog box will scroll itself to find your file. For example say you're looking for a file named 976-8.ipt in a directory full of files (including other dash numbers of the same file). In the open dialog box start typing in 9 (jumps to files starting with "9"), 7 (jumps to files with "97"), and continue typing in as much as you need to jump to that area of files in the directory. Works great if you know part of a file name but not the whole name. This also works in Windows Explorer and most other file dialog boxes. I hope this eases your scroll wheel finger a little.
MechMan
accu-cad
Message 8 of 14 (60 Views)
Re:
12-09-2002 01:49 AM in reply to: *Dotson, Sean
i have done the same thing with out picking the first file. if you just start typing in the file dialog box it jumps as you described. I find this better because there is no accidental picking of an unwanted file or if you do not type fast enough it tends to "forget" what you were intending to do. example 976-8.ipt you type 9 the phone rings you answer then type 76-8. It forgets that you typed the 9 and jumps you back to file 76-8 not the intended 976-8. The dialog box will sit there all day waiting for your next input. Also if you type "o" you can edit it without redoing the search.
MechMan_
Message 9 of 14 (60 Views)
Re:
12-09-2002 02:14 AM in reply to: *Dotson, Sean
You're right, in IV you don't have to highlight the first file but in some applications (like Autocad) you do. You're also right about the delay. The entry has to be a continuous entry because after about a 1 second of no entry the search string starts over. Can you explain the "o" key and what it does? I'm too dense to understand.
MechMan
accu-cad
Message 10 of 14 (60 Views)
Re:
12-09-2002 02:20 AM in reply to: *Dotson, Sean
type o better known as a typing error. don't type the letter o. if I have a typing error we call it a type"o"
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
