I have found, that if youre doing a BIG animation, animator will crash.
But if you use the CamStudio Lossless Codec, and select zip-compression
(level 9),
you will be able to capture much longer video-clips without Animator
crashing.
It is a little slower, but worth it on large animations.
Jorgen Bjornes
Are you located in the Oslo-area, and need a Mechanical Engineer who really
knows Inventor?
I'm currently available for short-term, long-term or permanent jobs.
See www.bjornes.org for more info and resume (in Norwegian).
On Mon, 2 Jun 2003 01:31:30 -0700, Jorgen Bjornes wrote:
> While doing a big animation-project, I stumbled upon this treasure:
> "CamStudio Lossless Codec 1.0".
> It is a free codec, that can be used with great success when recording
> animations.
> It is lossless and fast (fast when using LZO compression), so the result
> (AVI-file) will be perfect.
> There are two different Compressions to choose from: LZO and ZIP.
> The LZO algorithm is very fast and is best used for screen capturing
> (using Animator).
> file-size is a little larger than techsmith.
> The GZIP (zlib) algorithm is most useful when you are not using this
> codec to do screen-capturing. (but ideal when doing post-processing, like
> editing in an video-editing software.)
> An AVI file already exists, and you want to convert or recompress the AVI
> file using CamStudio codec to take advantage of its lossless and temporal
> compression. The encoding with the GZIP algorithm is a slow process but
> it produces a small AVI file and that is ideal for archiving purposes.
> When encoding with a third party application, you will have to enable or
> force keyframes to take advantage of this codec's temporal compression.
> Otherwise every frame will be stored as a key frame and the resulting
> file size will be huge.
> I have not done any thourough testing, but here are my impressions:
> It is camparable to the TechSmith codec, BUT:
> -It is completely free.
> -It uses lessless compression, so picturequality seems better than
> Techsmith.
> -It works flawlessly with Animator. (at least for me, unlike some other
> codec's I have tried).
> -A little big filesize at first, but smaller than Techsmith if zip-
> compression is used in editing-software like Premiere. (still lossless).
> It can be downloaded freely at:
> http://www.rendersoftware.com/products/camstudio/codecs.htm
> I hope this will come in handy !!
