Inventor Forum
The application has used up the maximum allowable disk space
4 REPLIES 4
shuaib_cad
3697 Views, 4 Replies
I have some very serious problems when i am working in a big part with maximum features.
I get a message saying that:
The application has used up the maximum allowable disk space (1200 MB)
The second problem is:
The space in C: keeps increasing. I dont know how the space in C: increased even after having the ipt file in 😧
Please advice....!!!
Regards
K. Mohammed Shuaib
4 REPLIES 4
CCarreiras
in reply to: shuaib_cad
Hi!
Inventor uses  disk space as memory. Try to save often, and ofcourse, get more space in C:
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
shuaib_cad
in reply to: CCarreiras
but, i have enough space in C:....
the main problem is whenever i work in inventor i lose some space in C:..
how can i clear that space from C:..?
shuaib_cad
here is the screen shot of the error!
swalton
I just say yes to that prompt.  I have not seen any bad effects from doing so.
Inventor makes a temporary file to store the information required for the UNDO button.  If you do enough complicated work, IV fills up the temporary file and asks if it can make the file bigger.  I believe that IV deletes the file on shutdown, but I have never checked.  As long as you have more room on your c: drive, it will not cause a problem.
Steve Walton
Inventor 2023
Vault Professional 2023
