Inventor Forum
Textur Manipulators - XY Manipulation
4 REPLIES 4
bryndisbe
1136 Views, 4 Replies
Hi everyone,
I have a Problem with the Textur Manipulators. I made a new Textur from a Picture that I had, then I wanted to roatate and position the picture on the 2D Surface sheet metall, that I constructed in 3D.
I cant move the Picture in x or y-direction. I can rotate it and scale it but not wove it in x-y direction.
Are there some installations that I have to make, to have the possibility to move the picture on the surface?
(I have tried to move the in the Text manipulator and in the "Darstellungs-Browser" for the Textures)
Can somebody help me
Thank you
Smiley Happy
4 REPLIES 4
in reply to: bryndisbe
I have same problem!!
I found the solution))
such movement only works in realistic textures mode
DanielKruger
This has become a major problem in my drawings. I use a .jpg to apply the texture of grout lines on our products however, without being able to move the texture on the surface I cannot match the grout lines where one surface meets another. My boss is not excited that the grout lines don't match up but I don't know what to do about it.
Why would Rotate and Scale work in shaded mode but Move only work in Realistic? Considering you can't use Realistic in your drawing files anyways.
bryndisbe
I have found out, that the quickest way to do something like that is to use decals. Information can be found in the wikiHelp.
it is not the Surface itself but it is something 🙂
