Inventor Forum
Text won't appear on my Idw files
14 REPLIES 14
Message 1 of 15
974 Views, 14 Replies
I am using Autodesk Inventor Series 10. I have had recent problems adding text to my files. When I open up new files, I cannot add new text nor general notes. When I open old files the text and general notes I had drawn still appear; however I cannot add new text nor general notes.
In both situations (new files and old files), the "Undo" command recognizes that I had made a general note even though the note did not appear. In both situation, the "Undo" command fails to recognize that I had attempted to add text.
I have tried various solutions: This includes making sure all my layers are on, Trying different text styles, and looking in the database to see if anyone else had this problem.
Any help is appreciated.
14 REPLIES 14
Message 2 of 15
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009-SP1
PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
XP
Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Message 3 of 15
JDMather
Have you tried installing all Service Packs and Hotfixes?
Have you tried searching Google on Autodesk Inventor text?
Message 4 of 15
I tried the patch that was recommended. It reads "This Hotfix could not be installed because it is not designed for the version of Autodesk Inventor 10 that is installed on your computer." The "About Autodesk Inventor" tab says that I am running Autodesk Inventor 10 Release 10 Build 211m.
Also, I am running Windows XP pro. Do I have the wrong patch or is my problem something completly different that this?
Message 5 of 15
In addition to the response provided by the other fellow, I shall try your suggestions with checking on google and so forth.
Message 6 of 15
what service pack are you up to? I believe Inventor 10 went up to SP3a.
You might need all service packs installed before installing that
hotfix.
Message 7 of 15
mcgyvr
Hotfix for INV10
http://images.autodesk.com/adsk/files/ts1069046_r10.zip
Message 8 of 15
I found the service packs and am installing the lastest one right now. Edited by: stadiumtraveler on Feb 3, 2009 7:46 PM
Message 9 of 15
They have to be installed sequentially. Look in Help >
About Inventor for the latest installed SP.
Expert
Expert.
PcCillin AV
XP
Message 10 of 15
I'll try to make this as simple as possible.
In Inventor, go to your Help menu, then select "About Autodesk Inventor"
On the next screen you should see what build, Release and SP (Service
Packs, if any)
If you see "10 SP3a" then that means you are up to Service Pack 3a. If
you see something other than SP3a (none listed or SP1 or 2) then you
should install the Service Packs.
All of the SP's will have to be installed in the order they were
released. In other words, in order to install SP2, you will need SP1
installed first.
Depending on what "About Autodesk Inventor" displayed to you as
installed SP's, follow the links below as needed to obtain and install
any SP's you are missing.
link to Inventor 10 Series SP1 (Inventor10_ais_SP1.exe)
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=5596411&linkID=9242019
There is a "Readme" file/link on that page that will tell you how to
install it.
link to Inventor 10 Series SP2 (Inventor10_ais_SP2.exe)
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=5973751&linkID=9242019
Same thing with a "Readme" file/link here...
link to Inventor 10 Series SP3a (Inventor10_ais_SP3a.exe)
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6418565&linkID=9242019
Same thing with a "Readme" file/link...
After you've made sure you are up to SP3a, try to install/apply that
hotfix once more.
HTH
Message 11 of 15
The problem was fixed. Thanks for your help.
Message 12 of 15
The problem is fixed. Thanks for the help.
Message 13 of 15
guillermo.canon
These SP are avalilables en the Autodesk web any more.
Anyone Knows where can I get this SP for Inventor 10?
Message 14 of 15
JDMather
in reply to: guillermo.canon
http://teknigroup.com/
Message 15 of 15
in reply to: JDMather
Legacy service packs are available at:
http://teknigroup.com >> Downloads
