Inventor General
LawrenceFHoughton
Message 1 of 10 (567 Views)
Text created on filled area : Now you see it : now you don't
567 Views, 9 Replies
06-03-2013 12:42 PM
How can I ensure that text appears on top of a filled area when created in a sketch?
I found when I moved to IV 2014 that text was disappearing from my title blocks when I reopened drawings.
I have played around with text and filled areas in sketches, and symbols.
I find that when opened and reopened, some times the text is obliterated sometimes not and somtimes partially.
Text ok when added on top of an existing sketch in an idw.
W7-64 pro    Quaddro 2000 (latest driver)
Employee
Yijiang.Cai
Message 2 of 10 (501 Views)
Re: Text created on filled area : Now you see it : now you don't
06-05-2013 02:41 AM in reply to: LawrenceFHoughton
I can't reproduce it from scratch, maybe some key steps are missing. Could you attach the dataset or provide more details?
River Cai
Inventor Quality Assurance Team
LawrenceFHoughton
Message 3 of 10 (471 Views)
06-05-2013 07:25 AM in reply to: Yijiang.Cai
I have just retried to reproduce it myself. What I found was that in making a test symbol and a title block, text was covered by a filled area and not by a hatched area. This time.
I then opened a new idw and immediately created a sketch. Initially fill obliterated text. Then when I moved text and sketches arround, sometimes the text came to foreground, sometimes background.
Also some partial obliterates. See attached.
Text created outside the sketch environment always seems to be in the foreground.
It seems that predominently  Fill obliterates Text in IV2014.
Is there a way to control the draw order? A control to move Fill to the back and text to the forground?
LawrenceFHoughton
Message 4 of 10 (439 Views)
06-18-2013 01:42 PM in reply to: LawrenceFHoughton
Not got any help on this problem. I have numerous title blocks that are affected that have to be modified when ever accessed. Time consuming.  Title blocks I have used for years. Problem only appeared when I upgraded to IV2014. Is there a control to bring text to front?
Employee
Yijiang.Cai
Message 5 of 10 (412 Views)
06-18-2013 09:55 PM in reply to: LawrenceFHoughton
When taking the same workflow in R2013, the same behavior happens. Now there is no control or option to bring the text to front or back. And one issue DID 1500725 has been logged in our tracking system.
I am really interested that what is the behavior from your side in the previous release before R2014. Could you provide some more details about that?
River Cai
LawrenceFHoughton
Message 6 of 10 (389 Views)
06-19-2013 07:35 AM in reply to: Yijiang.Cai
I do not have 2013 installed anymore. I am absolutely sure
it did not happen until I installed 2014.
I hope whoever did this to me gets permanent hemorrhoids.
I was hoping to be able to retro-correct using the resource
manager, but unfortunately it is limited in its usefulness
because it cannot deal with subdirectories of which I have
many.
Employee
Yijiang.Cai
Message 7 of 10 (373 Views)
06-19-2013 07:33 PM in reply to: LawrenceFHoughton
Many thanks for you to continue providing the comments on this issue! I am keeping investigating this issue, finally I got the difference between R2013 and R2014. Please see the attached image for the behavior. We could see the text in R2013, although the text is behind the hatch. But it disappears in R2014.
Is that what you concern much? This should be an unexpected behavior here, and we will look into this.
River Cai
LawrenceFHoughton
Message 8 of 10 (368 Views)
06-19-2013 08:08 PM in reply to: Yijiang.Cai
I am glad that you are seeing the behavior and it is thus not due to my
hardware.
It concerns me because I unfortunately used the fill in a title block. At
the time the text was visible over the past 5 or so years. Now when I open
the drawing there is no text. No drawing number, no dates, no info.
The text does not appear when printed either.
A solution would be welcome.
I would be surprised if this effect is confined to me.
Thanks for working on it.
Employee
Yijiang.Cai
Message 9 of 10 (302 Views)
06-20-2013 07:31 PM in reply to: LawrenceFHoughton
Many thanks for you to report this issue to us!
One issue has already been tracked in our database, and it is being investigated now. And we got one workaround - It will work fine when changing the graphics setting "Performace" within Application options -> Hardware dialog to "Compatibility". Please have a try.
Hope it helpful for you!
River Cai
LawrenceFHoughton
Message 10 of 10 (256 Views)
06-25-2013 10:10 AM in reply to: Yijiang.Cai
Yes it works for me.
Thanks. You are officially on my genius list
. Lawrence
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
