Inventor Forum
Text Parameter- Equation value & Nominal Value
1 REPLY 1
shmartin89
634 Views, 1 Reply
Is there any way in which the text of a text parameter, which is in the equation column, can be replicated into the nominal value column in the parameters table? I want to reference the value of the parameter in Custom iProperties but it always comes up as blank because it has no value.
I need it to update automatically, e.g not entering the value manually.
Cheers
Sandy
1 REPLY 1
jingyi.liu
in reply to: shmartin89
Hi Sandy
You can try iLogic to address your requirement, it's quite easy.
iProperties.Value("Custom", "Your Custom iProperty Name")=Text
Here,  Text stands for a text parameter in f(x) table.
Jingyi Liu
Inventor Product Manager
