Hello!
I have been working with Inventor for many years an are now trying to use ACE to make electrical drawings and get use for the interoperability of ACE-Inventor. I am also new to electrical drawings.
The problem I ran into is when I have schematic terminals (see attached pic) with different wires attached to both ends and try to export those to Inventor.
The schematic terminal seems to only accept one pin (number) while the Inventor (3D) terminal model (see attached pic) has two pins which ends up with that all automatic wiring connects to only one side of the terminal after importing the XML-file (import harness data).
I have tried to edit the correct pins to PinL and PinR properties of the terminals without any effect.
Can the terminals only have one pin?
Should two terminals represent one physical terminal? If so, how do I connect the terminals without getting a wire between them?
Have I missed something or should I do this in another way?
/Br T
Hi, TobiasZetterberg2067,
I suggest to post this topic on Autocad Electrical forum: http://forums.autodesk.com/t5/AutoCAD-Electrical/bd-p/38 for more Electrical experts to take a look.
Kevin Li
Quality Assurance Team
Autodesk, Inc.
