Inventor Forum
Tension springs
4 REPLIES 4
210 Views, 4 Replies
Tension springs
Have found method of creating tension springs
beyond 1/4" with high resolution.
create 1 (one) coil using wire dia and o.d. of
spring, save according to size
create 1 clip end on single coil that you have
created and save according to size as clip end.
open new assy dwg insert single coil array number
of coils need to accomplish lenght of coil less
clip end minus 2 coils.
insert clip end constrain to faces, constrain
(fit) using wire dia's, constrain (x or y or z)
axis for fully constrained clip end
repeat for other end clip end rotating before
constraining.
This gives a high resolution and quick tension
spring drawing.
4 REPLIES 4
How about a post to CF?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Have
to size
created and save
of coils need to
constraining.
spring
drawing.
Sorry to bother you but who or what is CF
and do you and an address
Thank you
You may post attachments in the
CUSTOMER FILES newsgroup. Please move
the end of part marker to the top of
the file and/or zip the files to save
space. You can find the customer files
newsgroups here:
WEBBASED
Inventor CF (Customer Files):
href="http://discussion.autodesk.com/WebX?14@212.cBvfaFpMoE5.1@.f15ad3a">http://discussion.autodesk...
NTTP
href="news://discussion.autodesk.com/autodesk.inventor.customer-files">news://discussion.autodesk.c...
The
only execption is that users CAN post small images to the
actual discussion
thread if the image will help the continunity of the
thread.
The images
must be in jpeg (JPG) format and smaller than 200kb.
Have bmp's up there
